Super_Dave
Aug 13, 2014Explorer II
You have to run a minimum air pressure at all times or you risk hurting the bags. If they go empty on you, it is possible you will be buying a replacement bag. When empty, they do make the ride harsh because there is always pressure in them.
I believe that this is a myth or applies to trucks with weak springs or get heavily loaded while the bags are empty. I use a stem core removal tool on my valves when I'm not running the camper. I have had no problems.
44,071 PostsLatest Activity: Aug 30, 2026
