DinTulsa
Dec 13, 2017Explorer
I would recommend a WD hitch with sway control. I pull a 10,500lb TT with a tongue weight of 1575lbs and it needs WD to get the weight back on the front axle. My hitch is rated for 1,700lbs but that is only with a WD hitch. If you are fully loaded on a 30+ ft TT your tongue weight will creep up.
I pull with the Blue OX sway pro hitch. It is my first WD hitch so I don't have anything to compare it to, but it pulls straight and is quite.
