Terryallan
May 14, 2017Explorer II
For the Op. IF your TT tracks correctly with out the sway control. you are good to go. but do get it fixed so that IF some one cuts you off, or you have to swerve for one reason or another. The sway control is there to help. A Tt that is setup correctly should NOT sway in normal towing.
