rbpru wrote:
When you add a WD hitch and the TT and truck should sit level again.
This is what the WD hitch is supposed to do.
If by, "sit level again", you mean that the truck should drop by the same amount front and rear -- your statement is not correct.
With a properly-adjusted WDH, the truck might have a load equal to 0-25% of tongue weight
removed from the front axle,
and a load equal to 75%-125% of tongue weight
added to the rear axle.
With a properly-adjusted WDH, the front should not be lower than the unhithched height, and might be above unhitched.
The rear should always be lower than unhitched height -- perhaps 1.5-2" lower.
With no WD applied, a load equal to about 40-50% of tongue weight will be removed from the front axle,
and a load equal to about 140-150% of tongue weight will be added to the rear axle.
If you're not using a WDH, it would be prudent to take the loaded combination to a scales to ensure the truck's rear axle is not overloaded.
Ron
