Sped's avatar
Sped
Antifreeze NOT Bypassing Water Heater
I got the red valve on bypass and the blue valve on winterize. It’s sucking up the pink juice and spitting it out the water heater drain on the outside of the camper.
These valves seem so basic, plastic, and sort of bombproof….
Can these valves break go bad?
Am I missing something obvious?
Dan
  • There should be 3 valves to turn, close the cold going into the tank and the hot going out and open the bybass. that will circulate around the tank.
