ib516
Nov 05, 2018Explorer II
blofgren wrote:rhagfo wrote:LanceRKeys wrote:
Hannibal, what are you towing with your 5.4? I like the sound of a V8 working hard as well, but also like how I can put my diesel in 6th gear, set the cruise and just chew up the miles. I’m sure these new gas engines would pull just as well as my diesel. I just hope it is a long time before I have to make that choice!
Well looked at Hannibal's signature. He doesn't really need a diesel. Less than 9,000# is NOT heavy! Lets add 4,000# to that and see if he has the same feelings?
2017 Jayco 28RLS TT
Weights
Unloaded Vehicle Weight (lbs) 6,405
Dry Hitch Weight (lbs) 700
Gross Vehicle Weight Rating (lbs) 8,750
Cargo Carrying Capacity (lbs) 2,345
Measurements
Exterior Length 32' 5"
Exterior Width 96"
Exterior Height with A/C 134"
Interior Height 81"
Wheel Base 252"
Exactly; I was at that weight 2 fivers ago and there is a BIG difference from that point and the 16k lbs that I am at now. Add in the extreme mountain passes here in BC and I would NOT want to tow my current fiver with a gasser.
And for the record, I'm not a gas hater (I'm shopping for one now to tow my boat).
If I was towing 16k over mountain passes regularly, I'd go for the diesel and suck up the negatives for the exhaust brake and extra towing power.
44,068 PostsLatest Activity: Jun 10, 2026
