rickhise's avatar
rickhise
Any help appreciated
Our new single axle Salem ultra light camper unit, isn't very stable, it is a little over 20 ft. ( not an issue till once in bed for the evening)
My issue is the amount of movement that I recognize once Im in bed for the night.
Wife has the kid o s up front. Any stirring they do is quite noticeable .
I did install front end stabilizer sciccor (sp) type jacks. 4 jacks plus tongue jack
Spot is level un attached to vehicle. Tires are on the pavement,
Perhaps this low end unit ( you get what u pay for). Maybe others have tips.
Master bed is in the rear.
Thinking out loud. The table bed in front an those trips outside in the late night , maybe another set of jacks?
  • the bear II wrote:
    We used 4 jack stands like used on mobile homes like these:
    http://www.etrailer.com/Trailer-Jack/Ultra-Fab-Products/UF48-979003.html
    They remove all bounce from the frame and suspension. Lower the front place two at the rear, raise the front just past level and place the two in the front then lower the front onto the jack stands. Place one under the frame on each side at each corner. Rock solid.
    Considering your trailer is a single axle, I think the above (link) is a good choice. I have a set of 4 of these and they do help a lot. In a lot of ways, I think they are more stable than the scissor jacks factory installed on my camper. The scissor jacks have a bit of side ways motion also. Mine are turned at a 45 degree angle from the frame. I think by turning them it's suppose to help prevent direct side-to-side or front-to-back motion. When you look at all 4, they are aligned in an X pattern. Still I get motion. But when I add the self-standing jacks (above link), it seems to reduce the movement a lot.
    We don't have young kids with us any more, it's just the wife and I and the dog and the cat. So movement does not bother us any more. It's kind of like being on a boat. You know there is movement, so you just accept it. Actually, a little movement when the wind blows is kind of nice!
  • I had this problem. Greatly reduced it once I realized it was caused by the tires rolling slightly. I made a wheel brake that goes between the two axles. Your dilema being a single axle is different. I would suggest blocking both tires at both ends and see if that helps.
  • We used 4 jack stands like used on mobile homes like these:
  • I used to run the tongue jack down slightly bellow level and then drop the rear stabilizers. Now run the tongue jack back up to level and drop the front stabilizers. This will unload the suspension slightly and make a more stable trailer. As posted above chock the tires from both sides to reduce fore/aft motion.
  • Sure sounds to me like you are not putting enough pressure on the stabilizers. When I screw mine down (as tight as can get them) I also will make at least one more pass. That first one could get lifted as you do the others.
    One thing I have seen people do that I strongly DO NOT recommend is lowering or raising the the lift jack and extend your stabilizers then setting back down. Stabilizers are not meant to lift the TT. You will bend them.
  • How much pressure do you place on the stabilizers? Sounds to me like your not exerting enough pressure. Also, do you use wheel chocks?
