valhalla360
Jun 04, 2019Navigator
Soft spots needs to be defined a little more. Is the exterior rusting thru? It would be odd for the interior to rust as it's always coated with oil.
Bedliner might help or it might make it worse. Worked on some research back in college for steel rebar looking at bare steel vs epoxy coated steel. The worst option by far was epoxy coating where the coating was compromised...it tended to trap moisture and accelerate corrosion.
