HappyCamper44's avatar
Jan 25, 2016
Any other ideas while I have roof off?
Already in the process of taking the roof off of our 1997 27ft travel trailer, and thought I'd ask if anyone might have any "do's", "don'ts" or modifications other than what I have in my list below.
1-Repair/replace any damaged wood structure
2-going to run new RG6U Quad shield TV cable throughout
3-check/repair a/c duct work
4-add insulation if needed
5-add in switch/wiring for LED light strip outside under awning
6-move radio antenna from roof to exterior side wall
  • Insulation would be my priority. Due to the small amount of area, paying someone to come in and spray foam would be ideal.
    The ductwork is horribly insulated as well, so it would be awesome to get it sealed up nicely.
    If you've ever considered any LED strip lighting inside, now would be the time to run the wires for it. And definitely run wiring for any outside LED under awning and such.
    Might even be a good time to sketch out a wiring diagram of what is in there, just so you will know if needed, in the future.
    Did I mention insulation? :-)
  • You might prewire just in case you or a future owner wants to add Solar.
  • Maybe you can upgrade to a better insulation and install additional or double the 'rafters' to strengthen the roof?
  • I'd run a wire chase from one end to the other or to places you might need to pull wiring later. This would have saved me alot of work under mine to get the remote camera wired.
