Rock2's avatar
Rock2
Any problem with 2006 Aliner?
I would like to check with you before I buy a used Aliner from the private owner. I remember few years ago someone mentioned about the problem with the floor that tends to warp? Problem is I am not sure if 2006 is part of the group or not. I would appreciate it for your help. Many thanks!
  • Aliners before 2007 are prone to have bad floors, so be sure to check it very carefully for water damage.
  • Purchased a 1994 Aliner in 2004 and I sold it in 2007. The only problem I had was at the door. apparently when it rained some water entered around the door opening and got the plywood floor wet. Over time the floor became soft and I had to make a repair. Also I had small leakage around the windows. The windows then were held in with screws so I removed them and recalked. Other than that every thing was good.
    Have had two Aliners since, an Alite and presently have a 2004 Aliner DL with no problems with either.
    See My Campers.
