- On a 2 3/8" diameter axle, the lift gained is 5 1/4"
- The travel distance does not change, so I don't see the need for bump stops, let alone how you'd install them since there are no kits for them made by Dexter.
- GordonThreeExplorerExactly... Looking for info based on reading those instructions. Lots of uTube guys showing the flip but nothing about the bump.
- Snowman9000Explorer
GordonThree wrote:
Huntindog, what steps did you take to prevent over-extending (compressing?) of the suspension?
I'd like to flip my axle, as my little trailer is really low slung, but I'm concerned about having the leaf compress too far when it has more room to travel. Right now it just bottoms out on the frame if I hit a particularly bad bump.
You are supposed to add a bump stop. Can be rubber or steel.
Dexter Axle's instructions. See No. 14 - MACHZERExplorerThanks for all of the responses. I am going to start on the project in 2 weeks!
- HuntindogExplorer
GordonThree wrote:
Put bump stops on it. Just like how cars do it.
I'd like to flip my axle, as my little trailer is really low slung, but I'm concerned about having the leaf compress too far when it has more room to travel. Right now it just bottoms out on the frame if I hit a particularly bad bump. - sherpaxcExplorerwhere do you get this done at? Can an rv dealership do it or do I take it to a local autoshop? I'm not doing it myself as I lack the time and skill.
- spike99ExplorerI reposition axles under 3 of my trailers. No regrets at all.
Although, I did have to bring/use a portable step - to ensure bottom step gap wasn't a surprise. Especially before we had our morning coffee. (LOL!). - profdant139Explorer IINo regrets -- it was necessary to avoid dragging on steep driveways. Also, we tow the trailer on very rocky roads -- we needed the clearance.
But you will have increased wind resistance, and you will have a higher center of gravity. So I think there is greater risk of an accident during high speed swerving. (Try to avoid that.) ;)
Life is a series of compromises. - colliehaulerExplorer IIII had the axles flipped on my 1st TT, no issues whatsoever and eliminated the back end dragging. Trail-explorer is correct in terminology but people use the phrase flipped.
44,052 PostsLatest Activity: Nov 23, 2025
