bobndot
Jun 15, 2018Explorer III
Brands are brands.
If you like the floorplan and the unit has enough storage and the cabinet construction appears as if it will hold up because its real wood screwed in place not particle board with staples and maybe glue, then the rest will depend on the reputation of the dealership.
I would research the dealership and the mfg. to see if they honor out of network repair facilities to do warranty work while on the road away from home.
The other thing is your style of camping. If you use rv parks with hookups or if you boondock.
Boondockers try to stay away from temperamental 'Girard tankless water heaters' because they use more water when they work, less propane but more water . 'Truma plus' tankless is a better option but its a $1300.00 better option. I prefer the old style 6 gal gas/elec WH.
That and the floorplan are two of the things I base my purchase on.
