Larry37's avatar
Larry37
Anybody have 19.5 Vision rims on a Dodge
I just got a set of Vision 19.5 rims with Duratrac 245 /70 / 19.5 tires after installing them they vibrate terrible right out of drive way at about 45 mph and up.
I called place i got them (Wheel Rack In California ) and talked to Chris and he seemed very uninterested in helping said I probably threw a weight Since they vibrated immediately out of driveway I doubt that. I have less than 30 miles on them and haven't been over 60mph.
I have rotated tires on this truck before and never had any issues and I know the truck is solid didn't have any vibration immediately before changing tires and I used a torque wrench.
My question is this to those of you that have this set up.
Did you have to have them rebalanced ?
If so how did you balance - road force , centramatic, beads ?
I believe these are lug centric do I need centric rings ?
Should I remove the wheel stud clips ( maybe not letting wheels fit against hub properly)
Chris told me they use weights and beads did this work for you ?
Wheels are very heavy and it's cold out so looking for some advice before going through removing them again.
I have read several post about members that have this set up and recommended this shop. Hope I didn't make a $2000 mistake
I've also read lots of post about balancing , beads , centramatics etc.
Nearest place that can road force balance is about 2 hr away and not really wanting to pay for that if it's not the problem.
Hoping maybe it's just a install issue or something I overlooked.
Thanks
