CKNSLS
May 20, 2014Explorer
sacmarata wrote:
Comparing a gas truck to diesel is apples to orangutans.
Sure theres those that say "my gasser pulls my 8,000lb trailer just fine."
In my experience those are the ones afraid to own a diesel because of the undo stigma put on diesels from common problems of the old technogy Fords and Chevys.
Almost any gas truck will pull 8,000 lbs. Heck I used to pull an old 23' trihull beast of a boat with my Nissan 4 cylinder. Yes...it pulled it just fine...until I learned what just fine really meant that is. I upgraded to a 4.0 Ranger. WHOA boy. I could almost keep up with fraffic on the flats. This was livin!
Well, a few years later I got the 12 valve and I immediatelyI felt stupid telling everyone my Ranger was the bees knees all those years. It wasn't! It pulled the thing, sure! But did it keep up with traffic? No! Did I go through a clutch prematurely yes!
I know comparing a Ranger to a modern v8 gasser isnt the same but the illustration wasnt to compare the two but to show how one can talk themselves into believing something is "just fine" when it's not.
How many of you accept adequate with your camping gear or get by on just good enough. Thats what yer doin with a gasser pulling over 8,000lbs. It will NOT pull as good as a diesel. It WILL NOT last as long. It will have premature wear. It WONT be worth as much with 150K miles.
My 1994 Cummins 12 valve has 324k carefree miles and will out pull any gasser off the assembly line in 3/4 or 1 ton.
If anyone thinks 45mph on the interstate is safe they are jaded.
AND A GASSER WILL NOT COST $10,000.00 TO FIX THE FUEL SYSTEM-OR THE MOTOR. And you better tell those trucks in the right hand lanes when they are pulling real heavy (at 45 or 50mph up a Grade) THEY ARE UNSAFE!
Nobody is saying a gasser will out pull a diesel. What they are saying is that diesels are expensive to repair-and if one thinks they are not they are jaded. Also, if the resale value is more...it would seem a $10,000.00 repair would take the extra "chunk" of resale value right out the proverbial window.
Are you paying 60grand for a new truck that requires DEF when you truck finally wears out?
44,066 PostsLatest Activity: Mar 14, 2015
