sacmarata
May 29, 2014Explorer
Jarlaxle wrote:sacmarata wrote:
Comparing a gas truck to diesel is apples to orangutans.
Sure theres those that say "my gasser pulls my 8,000lb trailer just fine."
In my experience those are the ones afraid to own a diesel because of the undo stigma put on diesels from common problems of the old technogy Fords and Chevys.
Almost any gas truck will pull 8,000 lbs. Heck I used to pull an old 23' trihull beast of a boat with my Nissan 4 cylinder. Yes...it pulled it just fine...until I learned what just fine really meant that is. I upgraded to a 4.0 Ranger. WHOA boy. I could almost keep up with fraffic on the flats. This was livin!
Well, a few years later I got the 12 valve and I immediatelyI felt stupid telling everyone my Ranger was the bees knees all those years. It wasn't! It pulled the thing, sure! But did it keep up with traffic? No! Did I go through a clutch prematurely yes!
I know comparing a Ranger to a modern v8 gasser isnt the same but the illustration wasnt to compare the two but to show how one can talk themselves into believing something is "just fine" when it's not.
How many of you accept adequate with your camping gear or get by on just good enough. Thats what yer doin with a gasser pulling over 8,000lbs. It will NOT pull as good as a diesel. It WILL NOT last as long. It will have premature wear. It WONT be worth as much with 150K miles.
My 1994 Cummins 12 valve has 324k carefree miles and will out pull any gasser off the assembly line in 3/4 or 1 ton.
If anyone thinks 45mph on the interstate is safe they are jaded.
A 30-valve Ford V10 will suck the doors off your truck on any long grade! 362HP beats 215HP...this is basic physics!
Note: a local towing company has a gas repo truck...and that truck is quicker up hills than the 7.3 PSD trucks! Why? Because it has more horsepower!
The gasser did wear out, though...it needed a motor a while back. It only had 553,000 miles!
Who told you I only had 215hp??? I've stated repeatedly that my 12valve like most all others has almost completely free mods and is pushing over 300hp. I estimate mine around 360hp but not gonna spend the money on a dyno just to find out I was +/- 40hp.
A slightly modified Cummins 12V will run lower RPM than the V10, put out more useable torque in range and last longer.
I have a problem with running higher RPMs than necessary because higher RPM's mean (in some cases) increased temps and always mean increased wear. It's simple physics. If I run a piece of sand paper over a board 400 times a minute it will have less wear than if I ran the same piece 600 times a minute. To my knowledge gas pistons, cylinders, cranks, cams, bearings, valves, etc don't have spectacular advances over the same in diesel.
44,066 PostsLatest Activity: Mar 14, 2015
