dieselsyndrome wrote:
Broke my Hensley last week. Came off the I91 onto the 7 in Vermont had to brake a bit harder and heard the Hensley bump. After that the hitch started to make a "knocking" sound. I drove for about 10 minutes and then stopped. I checked the strut bars and they were still tight. Everything looked normal other than the hitch was off to one side. I added more grease and continued. When I got to the I90 I heard more of the "knocking" sound and pulled off at the next rest stop outside of Albany. The hitch was still off to one side, but everything looked ok (struts tight nothing looked out of the ordinary). I unhitched and re-centered the hitch manually and re-hitched. Added more grease and continued. No more noise everything seemed fine. Drove about 70-75 rock steady. Then after Syracuse got off onto the 690 and then off the highway and "bang". Trailer started swaying violently. I was able to stop and limp to the Camping World which was around the corner. Hitch destroyed. What a let down. Only about 25k on this thing. Good thing it didn't happen 5 minutes earlier. Ended up buying an Eaz-lift but not happy with it. Maybe time for a ProPride.
Hensley failure
I would send that back to Hensley and get it fixed under warranty, for what these things cost I would be hard pressed to just 86 it.
