imq707s's avatar
imq707s
Anyone had shrinking issues with DICOR caulking?
When I first picked up my used travel trailer back in June, I scrapped out all of the old caulking from the seams, cleaned the seams with some wax&grease remover solvent, and recaulked everything with DICOR non-self leveling lap sealant….that’s what everyone seemed to like that I talked to. I used the self-leveling stuff for the horizontal roof joints. Now, only a few months later I’ve noticed that although the self-leveling stuff that I used on the roof is holding up great, the non-leveling stuff that I used on the rest of the trailer joints is starting to shrink and pull away from the joint in a few places. The majority of the spots are right up against the plastic trim pieces on the vertical seams on the trailer where the front, back, and sides come together.
Has anyone else seen this problem with the DICOR non-self leveling caulking? When I scrap it all out, and redo it AGAIN….should I use something different??
Thanks!
  • I have been undergoing a similar issue, You can see my post in class c. I have never used dicor on the vertical surfaces. I use what Winnebago uses. I believe it is a high end silicone caulk. (nuflex 313) I know, many will say never to use silicone on an RV. But that is what the local RV shop told me to use, and so far, after 12 years, no problems, in terms of pulling away or leaks.
    That said, I have been in contact with dicor, for questions I had about dicor roof lap sealant. They have been most helpful and responsive. My suggestion is you e-mail them and ask
