gmckenzie's avatar
gmckenzie
Anyone have a GM 1500 with Max Trailering?
I'm trying to figure out if I can go from a 2001 GMC 2500HD that is starting to look old to a 1500 with the Max Trailering package.
I have a Cougar 30RKS. I have a Equal-i-zer 4 point hitch. I have weighed my trailer and truck. The only thing I haven't done is weigh the truck empty to see what my actual current payload is.
I'd like to move away from a diesel as I have a very short commute and end up parking it for 6 months over the winter and drive a beater. I am thinking of a gas truck.
Trailer weighs ~8,000 fully loaded as per my last run over a scale. Assume max load of 8,200 lbs. Tounge weight is 1,060 but weight transferred to the truck with the WD hitch set up is ~775 lbs. Weight on the trailer axles ~7,200.
Truck weight while hooked up is 8,650 lbs.
I know it isn't a correct comparison, but the total combined weight is 15,850. According to the brochure I looked through, the GCVWR for the 1500 with the max tow (5.3L 3.73 rear) is 7,600 KG or 16,720 lbs. I am below that now with the diesel so I can't see how I would be over the weight with the gas truck etc.
So, best I can tell is I would be under the tow rating (~11,000), under the combined (16,720) and the only question is would I be under the payload (~2,200).
The other option would be stepping up to another diesel and I just don't see that happening. I like my truck but don't pull enough to really need it and more often than not am driving 5 minutes to work.
Hope this makes some sense.
Who is towing with the Max Trailering package and what are you towing?
