gmckenzie's avatar
gmckenzie
Anyone have a GM 1500 with Max Trailering?
I'm trying to figure out if I can go from a 2001 GMC 2500HD that is starting to look old to a 1500 with the Max Trailering package.
I have a Cougar 30RKS. I have a Equal-i-zer 4 point hitch. I have weighed my trailer and truck. The only thing I haven't done is weigh the truck empty to see what my actual current payload is.
I'd like to move away from a diesel as I have a very short commute and end up parking it for 6 months over the winter and drive a beater. I am thinking of a gas truck.
Trailer weighs ~8,000 fully loaded as per my last run over a scale. Assume max load of 8,200 lbs. Tounge weight is 1,060 but weight transferred to the truck with the WD hitch set up is ~775 lbs. Weight on the trailer axles ~7,200.
Truck weight while hooked up is 8,650 lbs.
I know it isn't a correct comparison, but the total combined weight is 15,850. According to the brochure I looked through, the GCVWR for the 1500 with the max tow (5.3L 3.73 rear) is 7,600 KG or 16,720 lbs. I am below that now with the diesel so I can't see how I would be over the weight with the gas truck etc.
So, best I can tell is I would be under the tow rating (~11,000), under the combined (16,720) and the only question is would I be under the payload (~2,200).
The other option would be stepping up to another diesel and I just don't see that happening. I like my truck but don't pull enough to really need it and more often than not am driving 5 minutes to work.
Hope this makes some sense.
Who is towing with the Max Trailering package and what are you towing?
  • I have a 2015 SLE 1500 w/ max tow 5.3 6.5 box crew. Yellow sticker payload is 1985, my trailer is almost 1000 lbs more than yours and I have no problems towing our trailer. I paid 37400 in rosetown sk. You may be looking for power if you drive fast and find yourself trying to pass people, other than that you'll be good. I can post my scale weights if you really want.
  • gmckenzie wrote:
    campigloo wrote:
    Why not just get a 3/4 ton with a gas engine? Problem solved.
    $10K - $15K more money.
    I know Canada is weird, with your accents, low crime rates, and overall friendliness, but I would not expect there to be a $10K-$15K difference between a max 1500 and a 2500.
    We paid $37K for our Ram 2500 6.4L HEMI with the SLT trim package. MSRP was $43K. A comparable trim in a 1500 doesn't go for much less. Maybe $5K, if that, and probably less with a max package.
    If you have good credit, you should be able to finance through your bank for less than 4.99%, regardless of the truck. We financed our current truck through USAA at 2.1% for 48 months.
  • I think that's a good match. The 2015 5.3L has nearly identical power to the 6.0L in the HD, in a lot lighter truck. Performance should not be a problem, excepting that it will rev and downshift on hills compared to your diesel.
  • gmckenzie wrote:
    mooky stinks wrote:
    I just weighed my 2015 6.2 LTZ 4x4 Max Tow w/ Outback 277RL on the way to the CG packed for 4 days with DW and dog and a full tank of fuel. In other words the absolute heaviest that MY rig will ever be. Numbers are:
    Steer axle 3460 FAWR 3995
    Drive axle 3920 RAWR 4300
    Total TVW 7380 GVWR 7600
    Trailer axles 7400
    As you can see, I was under every rating but close to my GVWR. (220 lbs.)
    I tow approx. 1000 miles/year so a 3/4ton truck just doesn't make sense for me. I know because I did it for 2 years. The 6.2 MAY require better fuel when actually towing (which I use) but it runs fine on mid-grade the other 14000 miles/year that I drive. It also tows nicely on the NYS Thru-way at 65mph at 1700 rpm's.
    Do you know what your toungue weight is?
    1100 lbs
