aftermath
Aug 13, 2017Explorer III
mileshuff wrote:
We went from a standard popup to a Hybrid and skipped the high wall. The weight and cost of high walls led us to get a hybrid instead. Cost to do was marginal and the high walls weight required a larger vehicle than a standard popup. So a hybrid made much more sense. More room and faster setup and tear down. Our Starcraft 21SSO weighed 3800# dry and just under 5,000# fully loaded with gear, luggage and water tank filled.
I also went from a pop up, although not high walled, to a 21SSO. I question your statement about weight. Even if a tricked out high walled PU weighed a little more than the hybrid I would think that pulling the PU would be a lot easier. You will not have a big white box behind you. When it comes to towing, wind resistance is a much larger factor than weight alone.
44,068 PostsLatest Activity: Jun 27, 2026
