Bedlam
Jan 27, 2016Moderator
It's the same way with my CTD in the chassis cab. If it results in a more reliable engine for a longer period, I'm fine with that instead playing the numbers game. My previous PSD had 325 hp and 570 lb-ft while my current CTD has 325 hp and 750 lb-ft. Both have no problem keeping the speed limit while loaded on a grade, so I do not feel like I am missing anything. I upgraded from my last truck because I needed more payload and not because it was lacking power. My CTD does have torque management which results in "dead pedal" feel verses my old PSD, but I believe the new PSD also has management which limits the initial acceleration.
My truck is not used empty, so the chassis cab tune is probably a better match for my usage verses someone that frequently uses theirs for commuting or grocery getting and has a less severe duty cycle. You need to decide if your usage would benefit from a more conservative tune.
44,068 PostsLatest Activity: Jun 21, 2026
