woodhog
Mar 11, 2014Explorer
brholt wrote:
Interesting enough in the DRW Configurations Ram has a significantly lower hauling capacity (and GVWR) for the gas engine compared to the Diesel. This is very different than, for example, Ford. I have no idea why their gas DRW trucks are so low.
You can find a list, which you can adjust to be heavy duty and then rank by payload here:
Ram truck capacity
Thanks for this...
Most interesting, I wonder what reasoning they are using for those results, certainly different than most of us on here...
One would naturally think the gas engine is lighter and the payload would increase per the difference in the weight of the engines...
They seem to have it backwards...
Below from the above site...
Ram 3500 Dually
Tradesman
6.4-Liter HEMI® V8® MDS
crew | 8' | auto | 4x4
axle ratio
4.10
View/Print
Max Payload
4,514lbs
Max Towing
15,450l
Ram 3500 Dually
Tradesman
6.7L CUMMINS®® Turbo Diesel w/Exhaust Brake
axle ratio
4.10
View/Print
Max Payload
5,828lbs
Max Towing
21,650lbs
44,029 PostsLatest Activity: Jan 28, 2025
