Fordlover
Aug 21, 2015Explorer
Danattherock wrote:
Researching tow vehicle for first camper. Likely 3/4 ton longbed and 6.5-7k lb camper. We need good off road Performance for interests aside from camping so I researched this and talked with folks. Many had jacked up trucks with 37's and such.
But still, report good towing performance based on their feedback. I won't go to that extreme, but splitting middle of two vantage points if you will. Many say stock tires, and if you use off road tire or a lift kit, you will die. Which is ridiculous. The folks saying that are folks that have never towed with a lifted truck and bigger tires in my opinion.
Then again, I don't believe all that the young bucks propose either, jacked up 4-8" trucks with huge nobbies. They as a whole are buying this stuff for looks. I'm trying to factor in all opinions. That has me wanting custom wheels for wider rims, not just looks, to support 35x12.5x18 Cooper ST MAXX tires. Very good tow ratings on this tire as I can tell, but I'm new to this so research for yourself. Would value any feedback. Specs are on Cooper site.
A 2-4" suspension lift kit, and more commonly just a leveling kit is required to prevent any rubbing at full turn. I'm comfortable with either, but won't go beyond that due to possible handling issues, excessive raising of truck center of gravity, steering stabilizers often needed, compensatory stuff. But a mild suspension high quality lift or basic leveling kit with 35's I am feeling good about. This is based on a 3/4 ton truck. What's needed for clearance varies by make/model. Some get by with heavy duty front suspension or snow plow prep options.
The folks using ST MAXX I heard from are getting 40-50k per set, report low road noise, and good handling solo or towing. And great offroad performance of course, which is what motivates this compromise. I conceed it won't tow as well as a stock truck with highway tires. I just feel the degree to which this impacts towing is vastly overstated here, and elsewhere. We all have different needs, and highway tires won't be adequate for some of my interest.
18x9 or 18x10 wheels will avoid the marshmallo effect that many get when stuffing big tires on factory rims. This is a safety issue and would adversely effect towing performance in my opinion. I have no first hand knowledge and this could be a costly experiment. But I think that's unlikely. I'm willing to give the 35x12.5x18 a chance.
Would appreciate any feedback from folks actually towing with lifted trucks with bigger tires. I've read all the criticisms from folks about this from folks that only use stock ride height and tire sizes. If you have not towed with a lifted truck with bigger tires, you can't answer my question. Doesn't mean I don't appreciate and factor in that vantage point. But I'm in need of input from people actually towing with my intended lift and tire combo.
Dan
The fact is, features that make a vehicle superior off-road directly fly in the face of features that make a vehicle an ideal stable towing vehicle on-road.
I think the trick is, as you are doing, consider your modifications carefully.
This coming from someone who had an (old) truck lifted 6", on Super Swamper tires, front and rear locked differentials, and no swaybars front or rear. Yes I would drive it on the street, but towing even a small trailer (all I ever did) with it was not a relaxing experience. Mine was not done for looks, but strictly for aggressive off-road driving.
As you say, if you measured a stock truck, vs. a lifted truck with taller tires, there aren't many (any?) on-road performance tests that the modified truck will improve upon the stock vehicle. I don't feel comfortable recommending you reduce the handling/stability of a tow vehicle, only you can determine your acceptable comfort level.
