Huntindog
Aug 22, 2015Explorer
up2nogood wrote:Huntindog wrote:Danattherock wrote:
Regarding warranty, nothing I'm doing will void warranty.
Dan
Oh, it will void some of the warranty.
Larger tires WILL impart more stress on some components, such as the tranny, brakes, U joints steering components, etc. They will also lower the trucks ratings. How much is debatable, but it for sure will be operating in parameters beyond what it was designed for and tested for. Any component that the manufacturer thinks the larger tires may impart more stress on will likely have the warranty voided.
That said, there can be some things you may be able to do when buying the truck that can help.
When I bought my 96 Dodge 1 ton SRW, I wanted bigger tires. So I selected the optional 4.10 gears over the standard 3.55s. That simple cheap decision allowed me to use larger tires with the close to the same performance of the stock tires. It also protected the tranny and u joints from extra stress I did have premature service/replacement needed on the wheel bearings and brakes, which were adversely affected by the larger tires... Wanna play gotta pay.
As for leveling kits.. I am not really a fan of them for what you are wanting to accomplish. Since pickup trucks tend to be high in the rear when empty, leveling kits were invented to raise the front to match the rear. This works OK when empty. Put a load on the rear though and it will sag in the rear. Air bags can fix that, but it just shows how one mod can require the next etc. And my experience with air bag reliability has been less than I would expect. Seems like one is always leaking.
I also think that 35s are more than needed for 4x4 use. People who go that big are generally doing it for looks. The performance from larger tires starts to diminish after about 33" on full size trucks.
I have to disagree on warranty, I was in a Ram dealership yesterday , sitting on the showroom floor was a new Ram 2500 with at least a 4 inch lift on 35's , I doubt anyone would buy that truck without full warranty. I see those new trucks setup that way all the time, its a dealership thing.
I see it as well. I was even told by a dealer that anything that they installed, including tuners would be warranteed.
I did not buy from that dealer as I knew that he was LYING. The dealer doesn't warranty anything. In this case and in the OPs case (he stated that there were several lifted trucks on a GM dealers lot that he was looking at) it is GM that pays the warranty. Sure the dealer may tell you what he thinks you want to hear... But if he is willing to risk losing his dealership by lying and committing fraud to GM about a warranty claim... Then he will have no problem lying to you either.
And it is easier than ever before to get caught today. Ford puts black boxes in many (maybe all?) of their vehicles that record many things that can trip you up. GM has OnStar. It can tell GM just about anything they want to know.
When I first got my 2001 Chevy dually, a check engine light came on. I called Onstar. They did their diagnosis magic... Told me the fuel cap was loose.. They were right it was, and the light went out when I tightened it.
