Perrysburg_Dodg
May 11, 2017Explorer
I would look at the tires before adding bags. Did you have the tires aired to the max PSI on the tire sidewall? You said you have LT load range C on the rear? I will assume you have the same on the front as well? If not then you need to do so.
The 2017 f150 with the EB & ten speed should handle that trailer without any issues at all. There are guys on here claiming their older EB f150 is towing over 10,000# like a breeze. So something is definitely wrong here.
Don
Don
44,026 PostsLatest Activity: Feb 22, 2025
