brulaz
May 11, 2017Explorer
Perrysburg Dodgeboy wrote:
The 2017 f150 with the EB & ten speed should handle that trailer without any issues at all. There are guys on here claiming their older EB f150 is towing over 10,000# like a breeze. So something is definitely wrong here.
Have read elsewhere that the newer Al-bodies F150s are not as stable as the older Ecoboosts, and need a bit more work to get them to tow smoothly. Lighter suspension and weight most likely the problem. And you need an excellent anti-sway WDH if you're bumper tow.
Wonder if that 10 speed would help adjust the engine/tranny braking to maintain whatever downhill speed you want. Unless the extra gears are all overdrive?
Had an issue with the 1st-2nd gears on steep, slow descents with our 6 spd Ecoboost. Another gear in there might have helped.
44,056 PostsLatest Activity: May 04, 2014
