johndeerefarmer
May 11, 2017Explorer III
Perrysburg Dodgeboy wrote:
I would look at the tires before adding bags. Did you have the tires aired to the max PSI on the tire sidewall? You said you have LT load range C on the rear? I will assume you have the same on the front as well? If not then you need to do so.
The 2017 f150 with the EB & ten speed should handle that trailer without any issues at all. There are guys on here claiming their older EB f150 is towing over 10,000# like a breeze. So something is definitely wrong here.
Don
Goodyear Wrangler LT "c" all the way around. I have towed the same trailer with my '15 F150. I am mainly seeking input on how the new 10 speed and more powerful ecoboost does since I haven't gotten to try mine out yet
44,056 PostsLatest Activity: Jan 12, 2020
