RinconVTR
May 15, 2017Explorer
johndeerefarmer wrote:Groover wrote:goducks10 wrote:
You must have the Heavy Duty tow package with those LT tires. Makes sense towing your 5th wheel. Should be a good combo.
While the LT tires are standard on the max payload package (not tow package) they are an available option on all 4 wheel drives. I special ordered them on my 4wd max tow package 2016 F150. My biggest problem towing heavy is that the truck is a little light in the rear partly because of the aluminum body. I have to be careful taking off from a stop not to spin the tires. Also, I have to watch sharp turns offroad going down hill as the trailer tries to push the back end of the truck into a jacknife.
I have the max tow package and specifically ordered the LT tires.
Man, I sure hope you mean "max payload" package as well as "max tow". They are two different packages and you will NEED max payload towing that GD 5th.
44,056 PostsLatest Activity: Jan 12, 2020
