Steve_in_29
May 20, 2016Explorer
HMS Beagle wrote:Since "protect mode" is most likely a Ram specific factory feature as I said it isn't applicable. Plus from what hbski posted it sounds like it simply stops the system from constantly running as it tries to level the load that won't level.Steve_in_29 wrote:HMS Beagle wrote:
What is protect mode?
I'm about to air ride my Ford, trying to understand the lingo..
"Protect mode" is not applicable to your situation.
The air bags the OP is asking about are part of the Ram's factory suspension that take the place of most of the rear spring and not an aftermarket add-on.
That didn't quite explain what protect mode is.
What I am doing to the Ford will remove ALL of the rear spring, not just most of it. Not air bag assists. I assume protect mode has something to do with a blown bag or no air pressure, and I would be interested to know what Ram does.
Since you are going with a full replacement air-ride suspension I suggest you contact the manufacturer of that specific setup for what their system is programed to do.
44,056 PostsLatest Activity: May 04, 2014
