Dayle1 wrote:
You didn't state what the problem was with the TST system and w/o understanding that, it would be a c**p shoot to expect another system to perform better. I do know that of the major brands, the TST system has the faster sample rate, so if you don't have signal integrity issues, none will alert you faster than it can.
Here is what i found during an earlier investigation:
TST, 6 seconds
Pressure Pro, 7 seconds
Tire Minder, 6 seconds
Doran, 12 seconds (implied but not stated)
Well my TST system is the older non-flow thru and it take a lot longer than your times to slowly cycle thru all the wheels. It is set up for a 16 wheeler and even if you only have 4 tires with the sensors it crawls thru all 16, one at a time.
I hope this Charchet system is better because it supposedly has real time monitoring of all 4 wheels and shows all four.
