bobndot
Feb 12, 2016Explorer III
Things that I would question only because I don't know the answer.
Is it worth it to swap out an EQ. suspension from one brand to another.......
on a non slide TT with 3500# axles ? Things that work or been tested on a HD axle might not have as much affect on a light weight axle.
Would a set of shocks be a better option coupled with the OEM Mor-Ryde that you already have ? IT might be money better spent.
If you do this and the new unit has grease fittings, make sure they installed on the inside , otherwise you might have to remove tires to grease it.
I was told to use bronze parts if that option is offered.
(I meant to type bronze instead of brass, thank you rhagfo)
44,056 PostsLatest Activity: Mar 02, 2026
