SoCalDesertRid1
Dec 01, 2013Explorer II
Ford changed the cab height way back in '99. The cab heights for Fords haven't changed since '99, that I'm aware of.
Dodge changed theirs in '03. I believe GM changed theirs in '02, or possibly '07.
Camper manufacturers started raising the overcab heights shortly thereafter.
So as long as you're buying a new, or near-new camper, it is very likely that it will fit your truck's cab height fine, without needing a riser platform in the bed. If it doesn't, you can lay some 2x4's down on the bed before loading the camper and that will likely be enough to clear the cab.
44,065 PostsLatest Activity: Apr 14, 2026
