jerem0621
Mar 16, 2018Explorer II
lawrosa wrote:jerem0621 wrote:
Yea, that’s the exact Apex I plan on buying. The calculator is cool if you have the trailer. I don’t have it yet so I have to use worst case scenario calculations and then ideal calculations. Those calculations help me ballpark my numbers pretty close.
Thanks!
Jeremiah
Max payload for your truck is 1700lbs or there abouts.. Whats your sticker say on the door?
My TW was 541lbs advertised. Buy time I loaded the camper with stuff, added 2nd battery and propane I went to 740lbs.
Payload on my door sticker is 1470 or so...( edit*** 1482.. just checked) Weights with full tank and me in the truck subtracted by rear axle weight left me with about the same. 1400+lbs.
I recommend weighing your truck before you buy anything...
Fuzz under 1,800 lbs on the sticker. Not as capable as my old duallys 3750 lbs but more than adaquate. Got about 1300 lbs left after fam and a full tank per the scale. Way way good on axles. Will start losing weight in the truck thanks to my oldest graduation from highs school next year.
