jmcgsd
Mar 25, 2016Explorer
I run my AC in a 29' TT With 1 EU2000i. I believe most small RV ACs will run with it. The problem is that older AC units require a good deal more current to start, so if the unit is relatively new (my TT is an '09) you're probably fine.
You won't be able to run much else while the AC is running and the genny will suck gas. I need to fill the tank on the eu2000 every couple of hours while running AC.
44,070 PostsLatest Activity: Aug 05, 2026
