Avid_Fox
Apr 15, 2021Explorer
jshupe wrote:Avid Fox wrote:
If the hj tie downs and resulting bed flex were the specific problem, I'd see at least some buckling at the bed's front also, but there isn't any.
The front of the beds are braced better than the rear, especially when you aren't running a tailgate to limit the twisting in the rear. Forces travel. I assure you, the damage you're seeing here could easily be (and are) originating from the front of the bed, at the tie-downs.
I don't disagree, but not for the same reasons. It's not exactly a HJ problem, it's that perhaps I didn't torque the turn buckles enough. Spring loaded fronts are spring loaded fronts, and they both allow movement. I'm thinking user error, not design error.
44,066 PostsLatest Activity: Mar 14, 2015
