bighatnohorse
Sep 06, 2022Explorer II
The first check I would make is a voltage check at the batteries with both the solar and the truck disconnected.
(Hopefully, you have an on/off switch to the solar panels.)
Then start the truck and wait for about a minute before checking the battery voltage again. The voltmeter should now be reading a higher voltage charge from the truck.
Are you getting a charge from the truck?
