elkhornsun wrote:
There is one manufacturer that makes a two part molded fiberglass camper that in theory should be exceptionally weather tight but in reality is more prone to letting water inside.
There are actually 2 that make the clamshell style, NL and BF. Now are you speaking from experience on the prone to leaking or is it hearsay that you are talking about? I happen to have one of those clamshell campers and the only leak I have had in mine was around the Heki skylight. Once that was resealed I have not had any other leaks in my camper in 1 and 1/2 years. I also had a 2005 NL and never had a leak in it. I'm speaking from experience of owning the product. I know there is one owner on here that has had leaking problems on his but for everyone of the clamshell leaking there are probably 10 others that are leaking and have had water intrusion to the point of having to rebuild the front overhang and rear wings and other places.
