Troutguy
Jan 24, 2018Explorer
hdspringer wrote:
Thanks for all the replies. I've read a lot of the previous arguments in previous forums and they are all well received. It sounds like the COG will be just fine with the LB. I'm sure there may be a little extra weight on the rears, but if my SB 3/4 ton with airbags handled it then a dually should do just fine. My biggest fear was it would not fit on my dually at all.
Your AF811 SB will fit on an 8’ box dually with the exception that the camper will not go all the way to the front of the box. It will look like d3500ram’s truck with the 18” gap. And you’ll need front jack extension brackets to clear the dually rear fenders.
Good luck with whatever you do.
TG
