AnEv942
May 19, 2019Nomad
The problem I see with using Torklift or any other scissor steps to add step is they fold from the bottom up- meaning top step is the mount point and would need to be mounted to the landing. Or simply replacing the bolted on step assy. They would fold up and be store- able much as existing step works.
The easiest, though most expensive, would be using the TorkLift Stow-N-Go setup attached to the landing. Likely need a four step (top tread flush to landing). Other than gaining 8" deep treads you'd get 7 1/2" between steps with contact to ground for more stability.
All that said I noted Northwood lists "Addl. Fox Landing steps" under options. NO other info so dont know exactly what it is. Found a video that also mention availability of "additional" step addition. https://youtu.be/LR2SnjprYMU?t=174 and mentioned again at end of video.
It may be another complete step but it may be and sounds like, one that is added to existing step. Might be worth contacting Northwood or your dealer.
