uglybear11
Aug 17, 2014Explorer
i have this same type of delamination. it is on the front of my trailer. there was a water leak in the areas where the warping or bubbling is. the leak is fixed. i removed the interior wall in an area to see what the issue was. the exterior fiberglass had a paper backing that was wet. i wiped off a small area of the cardboard as it tried to see what it was. so now i have a bubble / warp that is approx 8 * 8 to 10 inches ....... other than appearance, is there an issue? will this cause a failure? when i inspected from the inside, i made a cork board to cover the removed area. i can easily remove this again. should i do anything to prevent failure? i can live with the appearance with no problem.
44,067 PostsLatest Activity: Jun 05, 2026
