anutami
Sep 05, 2014Explorer III
Here is Northwoods response
"Nolan, I can see that your problem is caused by excessive heat that has distorted the glass, in short it has got to "HOT" under the cover that you are using, you might want to check with the folks that made the cover but this is not covered under the Northwood Warranty and is really just cosmetic at this time and really should not change much, but i would get ride of the cover for the summer and maybe use it when the weather changes.Thanks Matt"
44,067 PostsLatest Activity: Jun 05, 2026
