brholt's avatar
brholt
Explorer II
Aug 16, 2014
Arctic Fox front roof seam construction
Previously I had notices the fiberglass (after climbing up on the roof I'm wondering if it is some kind of plastic?) piece that forms the cab over and comes up to meet the rubber roof is a bit "wavey" on the top at the seam, like this (look to the left side of the picture):
Since it was like that since new I hadn't thought anything of it. Today, while trying to get rid of the evidence of my attempt to reduce the bug population of WA, ID, and MT, I noticed for the first time that the piece right in front of the seam could be "pushed down" on and would flex:
At first I had a moment of panic that I had some delamination but the seals are good, they have been checked regularity over its short life and it seams you can flex it over the entire roof seam except the corners. This leads me to believe it is designed to be "free floating." I was wondering if anybody know how Northwood constructs that part of the camper and joins the "cap" to the roof?
  • I've got the same thing on mine and I live in Vegas....hard for me to believe its moisture caused. My guess is their was not enough bonding material applied for the long haul. My 2012 AF990 ripples showed up two months ago in the heat of summer.
  • That's typical delamination. AF Filon is backed by cardboard. Any moisture causes just what you are seeing.
