ScottG
Aug 18, 2019Nomad
Thanks OB. I'll give you a jingle Mon.
FWIW, I cut a hole in the back of a cabinet to get a better look. I also cut the stack so I can see if the pipe is loose.
Turns out the fitting going into the tank is loose. They glued it down with some white goop that didn't hold. Maybe it broke loose because the pipe is being pulled sideways slightly and is under a strain. I should be able to correct that.
I can cut another hole in the bottom of the cabinet to get access to the fitting and probably pop it out. Then I need to find something better to glue the fitting in with. Epoxy? Or maybe there's a better fitting.
Jeez this thing has been a pile of junk.
Scott
Scott
44,066 PostsLatest Activity: Apr 16, 2026
