towpro
Oct 13, 2016Explorer
I currently have 180AH of AGM batteries, but no solar until next spring (it stayed with Wolf Creek).
and I already have a small 400w or so inverter, it does the job well, but I was just looking for a better way to do it.
last camper I had a 2P2T switch that switched the LINE side of the GFI protected outlets (feed) between shore and inverter power so all the outlets (accept microwave) would run on inverter. This allows you to plug in a laptop to charge at any outlet.
I was just trying to not be as intrusive, since the cutover switch is already there, and there is cables big enough to run my inverter already in generator box (the 12V cables to start generator) I thought I might go that route.
