towpro
Aug 08, 2016Explorer
Wardster wrote:
We did the same thing, but we ordered the 6" since we use a mattress topper. Anything thicker and we wouldn't be able to open the closet doors.
I went with OEM thickness and left the memory foam cover off the new (memory foam) mattress :).
I did add a reflective insulation barrier down first, then this breathable mess layer that is about 1/4" thick (designed to be used for vapor barrier between stucco walls and plywood), than mattress. I figured it can't hurt if air can pass under the mattress.
