joeshmoe
Jun 08, 2016Explorer III
Big Rig wrote:
UPDATE!!! I found their web site & they have a documents library. I found my model & the data sheet for it which I printed. My 2015 AF came with the Mach 1 PS EZ A/C White. It is 11,000 BTU & draws 9.5 amps on High in normal conditions.
Running Watts (cooling) Desert Condition (100 F. DB 72 F. WB Indoor, 95. DB Outdoor) is 1260 Watts. This seems to be the max watts in severe conditions.
I don't have any generator, built-in or Honda.
Big Rig (John)
That 9.5 Amp is nice, I can tell you. I think the numbers that Airxcel posts are a little on the high side, personally. On low, my unit barely pulls 1000 watts, give or take and not much more on high.
The Honda 2K genny outputs 1600 continuous watts @13.3A. So that extra 600W and leftover amps will easily power the fridge all the lights and even the TV which is all we need. The batteries are generally topped off, so the charge convertor isn't working overtime--not that it's ever been a problem.
44,066 PostsLatest Activity: May 15, 2026
