Bedlam
Dec 28, 2016Moderator
Wikel wrote:
AF needs to have this at the Seattle show in Feb. Thanks for the photos! Anymore?
From the photos, here is my guess of the layout:
1. To the right of the side door is a slide that holds the fridge and stove/oven.
2. Between the right slide and cabover is either the bath or rest of the kitchen. What I question in the layout is whether the bath is the forward center of the floor or if it is tucked forward of the kitchen slide. AF may have gone to a peninsula or island sink and counter.
3. The rear slide holds a 3-place couch or dual recliners.
4. The left slide holds the wardrobe and dinette.
5. The furnace has been moved to fixed wall in the left rear corner.
6. The generator has been moved to the left rear corner and forward of it is battery access.
7. The stairs and inline LPG bottles which are on a slide rack sit where the generator used to be positioned.
8. Shore power and the water heater have been moved from the front left corner to the front right.
9. I cannot locate where the dump was placed from the above two photos.
10. The left and rear slides appear to use the Schwintek mechanism, but you cannot see what the right slide is using.
