ScottG
Jul 27, 2014Nomad
n7bsn wrote:ScottG wrote:
They are better than avg. but still have problems. If you buy that model be sure to check the rollers for the slide from time to time especially when new. When the slide is out, lift the carpet flap and check the plastic rollers. They have a poor mounting method and tend to collapse into the floor. The slide will still work but it will labor.
This would not keep me from buying one but just be aware of the problem.
Never had that happen in 12 years of owning two units.
Also never have seen that complaint on the Northwoods products forum.
That's wonderful for you but you'll notice I did not make the comment on NW trailers in general. I was specific to the new model the OP is looking at. I never said it was some sort of historic issue with them.
A close friend of mine bought a new 25P (same chassis) and his did as I describe. The dealer said it had become a common issue. We looked at some newer arrivals at the dealership and they had been built in a similar manor and only time will tell if they still fail.
This is why I commented and I think the point is important.
