GeoBoy
Jul 28, 2014Explorer
ScottG wrote:
They are better than avg. but still have problems. If you buy that model be sure to check the rollers for the slide from time to time especially when new. When the slide is out, lift the carpet flap and check the plastic rollers. They have a poor mounting method and tend to collapse into the floor. The slide will still work but it will labor.
This would not keep me from buying one but just be aware of the problem.
Scott, I have owned a AF 25R and they do not have plastic rollers on this model slide. The 25R used a Power Gear slide mechanism and it is a above the floor slide that uses steel bearing mounted rollers that run in a steel track. The AF 25R as a whole is overbuilt with tons of storage and payload capacity. Great Trailer!
