Sport45
Mar 16, 2014Explorer II
travelnutz wrote:
Why it would be virtually impossible to have a gasoline engine at 16*1 compression ratio unless some new breakthru process is discovered in the future. Gasoline has a very low flash point and very subject to pre-ignition referred to as "engine knocking". Here is the explanation per engineering manuals from what is known today:
Gasoline (petrol) is a fuel for use in a spark-ignition engine. The fuel is mixed with air within its flammable limits and heated above its flash point, then ignited by the spark plug. In order to avoid preignition by the residual heat of a hot combustion chamber, the fuel must have a low flash point and a high autoignition temperature.
That's where direct injection comes into play. If the gasoline isn't in the air as it's being compressed it isn't prone to pre-ignition.
44,056 PostsLatest Activity: Dec 27, 2025
